Date/Time: Thu, 26 Nov 2026 03:53:30 +0000
Customized Trade DOM Columns
View Count: 510
| [2026-03-29 21:54:53] |
| User259545 - Posts: 26 |
Hi there, I know you’re busy, so I’ll keep this brief. I wanted to ask if you would consider adding an Ask Volume – Bid Volume Difference column to the DOM, under DOM Trade → Customize Chart/Trade Settings → Hidden Columns. You already provide the current traded Ask and Bid volume, which is extremely useful. Having a dedicated delta column alongside those would be a powerful addition for traders who rely on DOM-based order flow. It would offer a clean, at‑a‑glance read of net aggressive pressure without adding complexity to the interface. Thank you for your time, and for everything you continue to build into Sierra Chart. Best regards, Brett Walker |
| [2026-03-29 22:05:16] |
| Sierra_Chart Engineering - Posts: 25489 |
This is already supported in newer versions of Sierra Chart. You need to update Sierra Chart to the latest release. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
