Date/Time: Thu, 26 Nov 2026 03:53:25 +0000
[User Discussion] - Volume by price - continuous not reset
View Count: 332
| [2026-03-28 17:23:19] |
| RNCapital - Posts: 12 |
I have a vbp setup for tracking delta on a 30 minute basis. Every 30 minutes it resets to zero. I don’t want it to reset. I just want the numbers to continuously represent the delta over the previous 30 minutes. I feel like I’m overlooking an easy way to change this but no light bulb has gone off. Can you guide me in the right direction? Thanks,
| [2026-03-30 13:11:57] |
Set the following Inputs for the Volume by Price study: - Volume Graph Period Type: One Period at End of Fixed Time - Time Period Type for 'Fixed Time': Minutes - Time Period Length for 'Fixed Time': 30 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-30 21:21:19] |
Will do. Thank you
