Date/Time: Thu, 26 Nov 2026 03:53:28 +0000
DOM delta volume bars
View Count: 380
| [2026-03-27 19:14:52] |
| User300837 - Posts: 7 |
in the general graphic settings, when I go to the "Trade DOM current traded ask volume bid volume difference volume bar" I can only find 1 setting and I can only change the color for the positive delta volume bars. How can I change it also for the negatives?
Date Time Of Last Edit: 2026-03-27 19:19:38
Attachment Deleted. |
| [2026-03-27 19:18:35] |
There is an option for negative bars. Refer to the following and the item below it: https://www.sierrachart.com/index.php?page=doc/ChartTradingCustomizingGraphics.php#ChartDOMCurrentTradedAskVolumeBidVolumeDifferencePositiveVolumeBar Make sure you are on the latest release. Update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
