Date/Time: Thu, 26 Nov 2026 03:53:25 +0000
Ticks Problem
View Count: 318
[2026-03-26 21:37:46]
eli733 - Posts: 13
Hallo Sierra Team,
ich bitte Sie um Ihre Hilfe. Sehen Sie bitte das Foto unten .
Ich habe Futuren mit Linking 1,2,3,4,5 etc. gemacht. Trotzdem wenn ich ALLE Chartbooks aufmachen , sieht man ALLE TICKS Grafiken . Warum .
Jeder Chartbook hat Linking. Ich möchte , wenn ich beispielweise ES 500 Chartbook aufmache, dass ich nur die Daten von ES 500 sehen kann und die anderen Chartbooks nicht sehen will  Bitte um Ihre Hilfe . Vielen Dank
[2026-03-26 21:39:51]
From Google Translate:
Hello Sierra Team,
I am writing to ask for your assistance. Please take a look at the photo below.
I have set up futures charts using Linking Groups 1, 2, 3, 4, 5, etc. However, when I open *all* of my Chartbooks simultaneously, *all* of the tick charts become visible. Why is this happening?
Each Chartbook has its linking configured. My goal is that—for example, when I open the ES 500 Chartbook—I should only be able to see the data for the ES 500, and not see the other Chartbooks. I would greatly appreciate your help with this. Thank you very much.
There is no image attached, so we are not certain of the issue.
If you are stating that you are seeing charts for a chartbook that is not open, then this would mean that you have the option for "Window >> Window Always Visible" enabled for those charts. Refer to the following:
Window, CB and CW Menus: Window Always Visible (Window)
If it is something else, then we need more information on what is occurring.
