Date/Time: Thu, 26 Nov 2026 03:53:28 +0000
Fw: Fragen
View Count: 335
| [2026-03-26 21:35:11] |
| eli733 - Posts: 13 |
Hallo Sierra Team, der Indikator Price Volume rechts funktioniert von dem Chartbook nicht mehr. Was kann ich machen, damit den Indikator Price Volume wieder funktioniert ? Vielen Dank! --- |
| [2026-03-26 21:36:53] |
From Google Translate: Hello Sierra Team,
The "Price Volume" indicator on the right side of the chartbook is no longer working. What can I do to get the "Price Volume" indicator working again? Thank you very much! What do you mean it is no longer working? It displayed, but not updating? Is it not displayed? If it is present but not updating, then you would need to look at your setup for the Volume by Price study and see if you have it set in a way that it is not going to update for the given time. Perhaps you are only looking at a Day Session, and it is now the Evening Session? Or something similar? If it is not displayed at all, then do you have the Volume by Price study still on the chart? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
