Date/Time: Thu, 26 Nov 2026 03:53:30 +0000
Enable Teton Order Routing for AMP Futures
View Count: 707
| [2026-03-26 16:49:01] |
| User173364 - Posts: 1 |
Hello, I am setting up live trading with AMP Futures using Teton Order Routing. AMP has instructed me to contact Sierra Chart to enable Teton order routing for my account. Username: CarlLeese24 Broker: AMP Futures Please enable Teton Order Routing for my account and provide the routing username required to complete setup. Thank you. |
| [2026-03-26 18:40:43] |
| User135243 - Posts: 337 |
someone from support will answer, but this is crystal clear something the broker has to set up :)
| [2026-03-26 21:13:04] |
We have absolutely no idea why people at AMP keep stating that there is something Sierra Chart needs to do to enable Teton. This is 100% incorrect. We do not need to do anything. All of the work has to be done by your broker or by yourself. If AMP has finished setting up your Teton account, then you need to follow the instructions starting at Step #5 at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions Note that Step #5 is about setting up the Denali Exchange Data Feed, which you NEED to do. Be sure to follow the linked instructions in that section. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
