Date/Time: Thu, 26 Nov 2026 03:53:36 +0000
YMM26-CBOT
View Count: 312
[2026-03-25 18:48:54]
Bram - Posts: 28
dear Mr,
I would like to use the YM the same way i use the charts for the S&P, if i use YMM26 it's always intraday when using TPO. any Idea how i can change this so I have the entire 4000+ days on my screen?
i have a volume based contract back adjusted roll over.
many thanks in advance
[2026-03-25 18:51:06]
TPO Charts have to be intraday charts. You can not use daily historical data to build a TPO chart.
If you are setup for a Continuous Contract chart and you want 4000 days of data, then you need to set the "Days to Load" to be something a little greater than 4000, as you need to take into account the weekend data (days to load includes weekends, even though there may be no data for those days). Refer to the following:
Chart Settings: Days to Load for Intraday Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load)
