Date/Time: Wed, 25 Mar 2026 22:05:26 +0000
Tick Charts
View Count: 59
| [2026-03-25 14:32:33] |
| User629849 - Posts: 2 |
i'm trying to load tick charts of 25mill+. When i load the tick charts with high figures it seems to not be the actual 25million+ tick charts rather its a 1 mill tick chart or even less. How can i set it so its the actual 25 mill or 50 mill tick chart?
| [2026-03-25 16:53:20] |
| John - SC Support - Posts: 45296 |
You probably will not have a single day that has that many trades, so if you want to get a single bar with 25 million trades, you would need to set the option for "New Bar At Session Start" to "No". And you would need to load enough data in the chart to actually have that many trades. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-25 17:01:55] |
Where do i find the menu to put that option in? Sorry i'm new to Sierra. I have 6 years worth data i'll load more if i need too... Date Time Of Last Edit: 2026-03-25 17:04:26
| [2026-03-25 17:12:39] |
Refer to the following: Chart Settings: New Bar at Session Start (Chart >> Chart Settings >> Session Times >> Intraday Chart Session Times menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
