Date/Time: Thu, 26 Nov 2026 03:53:26 +0000
What Does the "Show Abbreviations" Setting in Tool Properties Do?
View Count: 326
| [2026-03-25 09:14:06] |
| Daniel - Backtesting.club - Posts: 177 |
Could you please explain exactly what the "Show Abbreviations" setting in the tool properties (Ray, Line, etc.) does? I couldn't find anything about it in the documentation. Thank you.
| [2026-03-25 15:15:43] |
We do not know what "Show Abbreviations" item you are referring to. There is no such item in Line or Ray tools Properties/Configuration. Please get us an image of where you are seeing this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-25 15:20:48] |
No problem. Here it is.
| [2026-03-25 16:36:20] |
Don't I feel foolish. That was just recently added and I did not know about it. And I had downgraded to an earlier release to test something and neglected to update - so when I looked for it in my build, it was not there. It applies only to the Chart Calculator, and toggles the display of the abbreviations in the display of the information for the Chart Calculator. Such as PD: for "Price Difference". We will see about removing that for drawings that do not actually have any use for it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
