Date/Time: Thu, 26 Nov 2026 03:41:35 +0000
Bug Found - “Chart DOM Current Trade Ask Volume Bid Volume Difference
View Count: 403
| [2026-03-23 23:28:02] |
| mastadom - Posts: 26 |
Hi Sierra Chart team, First off, thank you for adding delta to the DOM column - I really appreciate the update. I believe I’ve come across a bug: The setting “Chart DOM Current Trade Ask Volume Bid Volume Difference Negative Volume Bar” (Chart --> Graphics Settings) does not seem to persist. Each time I reopen Sierra Chart, it resets back to the default gray bar. All other delta column graphics settings appear to save and function correctly. This seems to be the only one that doesn’t retain its configuration. Date Time Of Last Edit: 2026-03-23 23:28:51
| [2026-03-24 02:37:04] |
| Sierra_Chart Engineering - Posts: 25489 |
This has already been resolved. Update Sierra Chart to the current version.
