Date/Time: Thu, 26 Nov 2026 03:41:35 +0000
Question about sc.VolumeAtPriceForBars
View Count: 1761
| [2026-03-23 23:18:20] |
| Tony - Posts: 738 |
ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars I have a custom study that store volumes of each level for current session in a array, the size of the array is MyArray[(DaysHigh-DaysLow)/TickSize], if I need to access Volume of current level, I just need to do this: MyArray[(sc.Close[sc.Index]-DaysLow)/TickSize] Everything works great until today. This morning, due to the volatility of the market, VbP has a gap in 6562.50 - 6571.50 range (roughly), so the sc.VolumeAtPriceForBars skipped those levels, and the size of the array is 36 levels short, and I wasn't able accurately get the number of volume, unless, I temporarily modify the code to fetch the number that is 36 ticks lower. I tried to modify the sample code as such: const s_VolumeAtPriceV2 *p_VolumeAtPrice=NULL;
int VAPSizeAtBarIndex = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index); for (int VAPIndex {0} ; VAPIndex<VAPSizeAtBarIndex; VAPIndex++) { if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex, &p_VolumeAtPrice)) ProfileValues[VAPIndex] = 0; else ProfileValues[VAPIndex] = p_VolumeAtPrice->Volume; } but it didn't work, wonder if there is a way to get around this? Thanks so much! |
| [2026-03-24 00:54:15] |
| Tony - Posts: 738 |
Problem solved, please ignore my original message, Thanks! const s_VolumeAtPriceV2 *p_VolumeAtPrice=NULL;
int VAPSizeAtBarIndex = sc.VolumeAtPriceForBars->GetSizeAtBarIndex(sc.Index); memset(ProfileValues, 0, sizeof(ProfileValues)); int LowestTick {(int)round(SessionLowest / sc.TickSize)}; for (int VAPIndex {0} ; VAPIndex<VAPSizeAtBarIndex; VAPIndex++) { if (!sc.VolumeAtPriceForBars->GetVAPElementAtIndex(sc.Index, VAPIndex, &p_VolumeAtPrice)) break; int TargetIndex {p_VolumeAtPrice->PriceInTicks - LowestTick}; ProfileValues[TargetIndex] = p_VolumeAtPrice->Volume; } Date Time Of Last Edit: 2026-03-25 14:19:15
