Date/Time: Thu, 26 Nov 2026 03:41:37 +0000
v2893 - float to double change ->> ALL GOOD
View Count: 340
| [2026-03-23 19:42:48] |
| User719512 - Posts: 548 |
Hi Sierra Chart Engineering, Saw the changes in v2893 and looks like you have a pattern for going forward and not breaking compatibility. Just wanted to drop a note that using v2893 headers, fixing the build breaks (building locally in my case) was very straightforward. Everything working after quick code updates and a rebuild. Just wanted to give you all Thumbs Up, and thanks for all the behind the scenes work for this float to double migration/support. |
