Date/Time: Thu, 26 Nov 2026 03:41:33 +0000
Control Bar Color Issue
View Count: 353
[2026-03-23 07:20:41]
User644914 - Posts: 2
I'm using version 2893.
1. The control bar colors are always displayed as RGB 255,255,255 in the Properties panel, regardless of the actual color selected.
2. The chosen color for a button is applied to all control bars. This means that changes made in control bar 8, for example, also affect control bar 1, 2, and so on.
[2026-03-23 17:35:50]
1. When you select the color for the control bar button on the Properties panel, you should get the Windows Color Picker window. The attached file is an example of this window.
2. Whatever color you choose for a specific button will apply to that button across all Control Bars.
imageScreenshot 2026-03-23 123311.png / V - Attached On 2026-03-23 17:35:47 UTC - Size: 15.08 KB - 144 views
