Date/Time: Thu, 26 Nov 2026 03:41:27 +0000
Risk Reward Tool Text
View Count: 413
| [2026-03-21 12:15:45] |
| User643802 - Posts: 26 |
Hi, Is it possible to remove/hide the text on risk reward tool? It is very cluttered. Thanks |
| [2026-03-23 14:41:39] |
anyone here?
| [2026-03-23 17:55:20] |
There are some controls to display some text for the Reward/Risk tool. In particular the following items: - Show Ticks - Show Currency Value - Show Points But the other text does not have a way to not be displayed. The only workaround for this would be to set the "Text Color" to be the same as the chart background. But, if your drawings are drawn on top of the bars, then you will see the text still over the bars. You may want to push the drawings to the back in this case. Refer to the following setting for this: Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
