Date/Time: Thu, 26 Nov 2026 03:41:37 +0000
Intraday Data Files Repeatedly Corrupting / Charts Not Loading
View Count: 441
| [2026-03-20 09:59:14] |
| User338995 - Posts: 16 |
Hello, I am having repeated issues with charts not loading. The loading process gets stuck (for example at 50–99%) and never completes. This has happened multiple times across MES and ES symbols. Deleting the .scid files fixes it temporarily, but the issue keeps returning. Examples: - MESM26_FUT_CME.scid - ESM26_FUT_CME.scid Steps I have taken: - Deleted .scid files - Re-downloaded data - Restarted Sierra Chart The issue continues to happen. Can you advise: 1. Why these files keep getting corrupted 2. What settings I should change to prevent this 3. If there is a deeper issue with my data or installation Thank you. |
Private File |
| [2026-03-20 16:18:34] |
| Sierra_Chart Engineering - Posts: 25489 |
What is the timeframe of chart bars in the chart? We want you to set those chart bars to 10 minutes per bar through Chart >> Chart Settings >> Bar Period. And see if you still have a problem. Refer to: Chart Settings: Bar Period This is not necessarily relevant, but we want you to update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-20 17:03:18
