Date/Time: Thu, 26 Nov 2026 03:41:28 +0000
Which way to recover delisted stocks
View Count: 372
| [2026-03-19 10:24:40] |
| User215421 - Posts: 3 |
Hello. I am a Sierra Chart customer since five years and I am working on Penny Stocks historical and intraday Charts. Unfortunately, before 2023, I removed the charts I have downloaded when the size of data folder exceed 60 Go. I wasn't conscious that the half of the stocks will be delisted after approximately two years. I have constitued a list of ~200 "legendary" bull movements, but a praticaly two thirds of it have been delisted since, which is very problematic for my studies. I would know, If there is a way, which way you advice to recover some delisted stocks like NAKD, SGOC or EYES. Thanks for your time. |
| [2026-03-20 14:52:36] |
| Sierra_Chart Engineering - Posts: 25489 |
First thing is to try to open in Sierra Chart an Intraday or Historical chart for those symbols. Normally you should be able to get the data for stocks that are no longer trading. However, due to some data reorganization done over the last 2 to 3 years, historical data for stocks which are not active may have been deleted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-20 14:53:10
