Date/Time: Thu, 26 Nov 2026 03:41:34 +0000
How to keep data working between Logins
View Count: 314
[2026-03-18 16:37:49]
User488391 - Posts: 1
I have a problem with keeping my data (MBO) on charts between logins. Every time I login, I have to go through the process of "finding how I turn the MBO data back on." I save my chart progress and chartbook. but when I login, I'm back to square one.
In Sierra Chart setting; I'm still "yes" on Subscribe.... and Separate connection....
What am I missing. Because I'm new, I have to trace back over my steps and figure out what's wrong.
Thanks for the all the quick responses you guys have given.
[2026-03-18 16:39:06]
We really would need to know what exactly you are doing that "brings back" the MBO data in order to help you overcome the issue.
The only thing we can think of is, that you are having to add the correct columns to your DOM. But if you save the charts with those columns displayed, then those charts should be fine when you open the chartbook again.
