Date/Time: Thu, 26 Nov 2026 03:41:30 +0000
Copy all charts to new chartbook
View Count: 445
[2026-03-18 06:16:27]
Rustam - Posts: 28
I noticed that when I copy all the charts into a new chartbook, the charts in the new chartbook are overlapping and are not arranged the same way as in the original chart. It wasn't like that before. what could be the reason?
Date Time Of Last Edit: 2026-03-20 05:26:30
[2026-03-20 16:05:56]
Sierra_Chart Engineering - Posts: 25489
The size and position of the duplicated charts will not be the same. This is by design.
And each chart window will be slightly offset from the other.
You can arrange them using the various window arrange commands from the Window menu.
[2026-03-21 11:25:56]
Rustam - Posts: 28
A few months ago it fit perfectly. If I now copy the charts into a new chartbook, then all charts are overlapping in one place. Is there a way to copy the charts 1-1 into a new chartbook?
[2026-03-21 19:36:49]
We will look this over and see what the solution needs to be.
[2026-03-22 05:33:11]
This issue will be resolved in the next release.
