Date/Time: Thu, 26 Nov 2026 03:41:35 +0000
Text Tag Input Field as Control Bar Command?
View Count: 298
| [2026-03-17 03:23:24] |
| User845712 - Posts: 10 |
Is there any way to be able to add the "Text Tag:" field from Trade Window>Set tab as one of the Available Control Bar Commands under Global Setting>Customize Control Bar? Would you be open to adding that in the future if not currently supported?
| Attachment Deleted. |
| [2026-03-17 14:31:46] |
We have noted this as a Feature Request. We can not say when we would get to any particular request. -- We do want to point out that the Text Tag is saved with an Order Configuration, so you can use the configurations to have different tags. And there is the option to use the "Configuration Name" as the text tag itself. Refer to the following: Basic Trading and the Trade Window: Set >> Use Config Name as Text Tag For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
