Date/Time: Thu, 26 Nov 2026 03:31:21 +0000
[User Discussion] - footprint
View Count: 679
[2026-03-16 14:54:37]
User140244 - Posts: 1
I need step-by-step help configuring Sierra Chart for Footprint / Order Flow.
My goal is to set up the chart so that it shows:
Footprint / Numbers Bars
Imbalances
POC (Point of Control)
Order Flow tools
A normal candlestick in the center of the bar
Bid and Ask displayed on the sides of the candlestick
At the moment, I can display Numbers Bars, but I cannot get the chart to appear in the format I want. I need the standard candlestick to remain visible in the middle, while the Bid and Ask values are shown clearly as part of the Footprint.
I would appreciate exact step-by-step instructions on how to configure this properly, including which studies to use and in what order.
Thank you.
