Date/Time: Sun, 01 Nov 2026 20:03:57 +0000
Encountered invalid field code (0) while reading chartbook file:
View Count: 1896
[2014-10-25 19:38:47]
User998601 - Posts: 13
I have run into the same problem reported earlier in October. I updated Sierra Chart to 1205 and then was unable to open any of my chartbooks. The log showed the invalid field code (0) message. I tried to copy the backup chartbooks as suggested in the support board thread, but they would not open either. I installed an earlier version of Sierra Charts (1199), but I still receive the same error message.
Below is a copy of the log. Please suggest a way to proceed. Thank you.
Jim
Software version: 1199 | 2014-10-25 12:18:41
Usage end date: 2015-02-12 | 2014-10-25 12:18:41
Enabled for: Advanced Features. | 2014-10-25 12:18:41
Enabled for: Advanced Features 2. | 2014-10-25 12:18:41
Enabled for: Sierra Chart Historical Data Service. | 2014-10-25 12:18:41
Allow Support for Sierra Chart Data Feeds is enabled. | 2014-10-25 12:18:41
Active service: SC Forex Data (FXCM) | 2014-10-25 12:18:41
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-10-25 12:18:41
2014-10-25 12:18:41 Local computer clock time | 2014-10-25 12:18:41
2014-10-25 19:18:41 GMT time | 2014-10-25 12:18:41
2014-10-25 12:18:41 Time zone adjusted time | 2014-10-25 12:18:41
Time difference to server time: 4 seconds. | 2014-10-25 12:18:41
Program path: C:\SierraChart\ | 2014-10-25 12:18:41
Data Files path: C:\SierraChart\Data\ | 2014-10-25 12:18:41
OS Version Number: 6.2 | 2014-10-25 12:18:41
Checking for new symbol settings for fxcm | 2014-10-25 12:18:41
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-10-25 12:18:41
HTTP connection to www.sierrachart.com:80 (1532) | Connected. | 2014-10-25 12:18:41
Requesting symbol settings for fxcm. Overwrite = on. | 2014-10-25 12:18:41
Symbol settings received. | 2014-10-25 12:18:43
Processed received symbol settings | 2014-10-25 12:18:43
SC Forex Data (FXCM) | Connecting to the server ds5.sierracharts.com. Port 443 | 2014-10-25 12:18:46
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-10-25 12:18:46
Socket (2200) | Connected. | 2014-10-25 12:18:46
SC Forex Data (FXCM) | Connected to server. | 2014-10-25 12:18:46
SC Forex Data (FXCM) | Sending logon request message. | 2014-10-25 12:18:46
SC Forex Data (FXCM) | Server Info - Server Name: . | 2014-10-25 12:18:46
SC Forex Data (FXCM) | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-10-25 12:18:46
SC Forex Data (FXCM) | Successfully connected. | 2014-10-25 12:18:46
HTTP connection to www.sierrachart.com:80 (1532) | Shutdown and closed. | 2014-10-25 12:21:43
Encountered invalid field code (0) while reading chartbook file: C:\SierraChart\Data\ChartbookExample.cht | 2014-10-25 12:21:47 *
Encountered invalid field code (0) while reading chartbook file: C:\SierraChart\Data\ES dash.cht | 2014-10-25 12:23:37 *
Date Time Of Last Edit: 2014-10-25 20:03:15
[2014-10-25 20:06:02]
There are many backup Chartbooks available in the Backups folder. Did you try all of them?
Here is the documentation:
http://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html#BackupChartbook
If you still have a problem post one of the Chartbooks here so we can test it. Here are instructions:
Date Time Of Last Edit: 2014-10-25 20:07:08
[2014-10-27 00:35:51]
I found three backup Chartbooks in the Backups folder and tried all three and received the invalid field code (0) while opening the chartbook. I am attaching
one of the chartbooks that failed.
attachment22.ES dash.back.cht - Attached On 2014-10-27 00:35:35 UTC - Size: 515.72 KB - 659 views
[2014-10-27 00:59:30]
Have you just recently updated Sierra Chart?
[2014-10-27 01:46:20]
Yes I updated the Sierra Charts a couple of days ago and that is what started all the trouble. After the update my chartbooks in my file no longer would upload even though I was clearly connected (as shown by ability to upload other raw data, and as shown by green bar)
[2014-10-27 01:53:58]
Do you remember what version you were previously running?
[2014-10-27 15:41:52]
No I do not remember; but I had not updated for months, maybe over a year, which unfortunately is why I decided to finally update and got into this problem.
[2014-10-27 23:41:22]
We are doing some testing and if it is all right with you, we would like to have a look at this problem using remote assistance. We can do this tomorrow.
Just make sure your current telephone number is on this page:
https://www.sierrachart.com/usercp.php?page=ManageAccountInfo
[2014-10-28 02:34:20]
Thank you for offer; but today I solved the problem. I asked the people at Order Flow Edge to e-mail their latest chartbook which my I.T.guy transferred to my Sierra Chart and it worked(using the 1199 update). So I don't know why there was a problem but I'm a happy camper now.
[2014-10-28 02:55:59]
OK this is good because we tried opening a Chartbook from about a year old version of Sierra Chart and it opened fine in the current version.
[2014-11-10 08:02:55]
User888375 - Posts: 4
I encounter the same problem. Just reactivated my account and I cannot access my previous chatbookks. Can you help me ? Remote assistance would be great.
Pierre
[2014-11-10 08:22:22]
Use a backup Chartbook file:
[2014-11-10 08:53:04]
It does not work. I can send you a chartbook file to check. It has been more than a year since theses charts were used in sierra. Would really like to restore them.
[2014-11-10 08:57:33]
Attach one of the Chartbooks you have a problem with here by following these instructions:
Also, if you have not used a Chartbook for a year, there will be back up files for it in the Sierra Chart Data Files Folder. These will have a cbak file extension. Try renaming one of these back up files with a standard cht file extension and opening it.
You can determine the path to this folder through Global Settings >> General Settings >> Data Files Folder.
Date Time Of Last Edit: 2014-11-10 08:58:17
[2014-11-10 09:04:12]
here is one of my previous chartbook.
Private File
Private File
[2014-11-10 19:49:51]
We have discovered the problem. We are going to be releasing 1210 in about a couple of hours which resolves this.
Date Time Of Last Edit: 2014-11-11 10:17:56
[2014-11-11 09:09:32]
Thanks, It is working now. You have been very reactive and helpful !
