Date/Time: Thu, 26 Nov 2026 03:31:23 +0000
Manage Chart Drawings Does Not Show All Drawings - Fixed/Resolved !
View Count: 397
| [2026-03-16 00:15:40] |
| User708541 - Posts: 215 |
In in Version 2890, I have "Drawing Type" set to All. Using OpenGL if that matters. For contract rollover, I want to adjust my drawings. However there is an issue. I have several dozen drawings on multiple charts and they are not showing up in the Manage Drawings tool. The only things showing up are a bar countdown timer 'Text' and the time of day, also 'Text'. But when I click on one, a totally different chart, and go to the drawing manager it shows a ton of drawings listed. Maybe possible all drawings from other charts combined into this Manage Drawings dialog box. But every drawing in this Manager box shows locked (not something I did) and the drawings will not adjust. Chart >> Chart Settings >> Chart Drawings >> Show Chart Drawings for Different Symbols is set to Yes if that helps. I FOUND THE ISSUE!! The drawings were associated with the previous symbol and I didn't change the dropdown to show the proper symbol Date Time Of Last Edit: 2026-03-16 00:30:01
