Date/Time: Thu, 26 Nov 2026 03:31:27 +0000
Help with intraday Historical Data
View Count: 414
| [2026-03-15 01:18:23] |
| WiddyTrading - Posts: 11 |
Hi, I've tried to dig into this myself, but couldn't find a good answer or solution. I am looking to get historical data on products like NISS-NQ,ES, etc. As well as TICK-NQ, TICK-ES. If I set my days to load to 1500 or 2000 like NQ or ES it only loads like 2 years of data. Is this a denali limitation or some setting that I am missing? Is there a way I could access this data for further back? appreciate the help, thank you. |
| [2026-03-15 04:46:06] |
| Sierra_Chart Engineering - Posts: 25489 |
Follow the instructions here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
