Date/Time: Thu, 26 Nov 2026 03:31:23 +0000
Set Control Bar Button Height?
View Count: 386
| [2026-03-12 23:56:30] |
| Mercrastius - Posts: 73 |
Along the same lines as setting the minimum character width of attached control bars, it would be great if we could also set the height of the buttons. As of now the only thing I've found to make the buttons larger is changing the point size of the button caption text. This has obvious drawbacks as the text becomes larger. Thanks |
| [2026-03-13 01:14:20] |
| Sierra_Chart Engineering - Posts: 25489 |
Yes the buttons are controlled by the text size. This is not anything we would change.
| [2026-03-13 05:07:25] |
Actually there is this setting which will increase the margin, above and below the text to make the buttons larger in height: Global Settings >>General Settings >> GUI >> Application GUI >> Small Pixel Amount Scaling Factor. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-13 05:07:52
