Date/Time: Thu, 26 Nov 2026 03:31:25 +0000
Reproducible bug
View Count: 417
[2026-03-12 08:29:03]
diatom - Posts: 9
v2888 64-bit ARM
MacOS M4 Max 128Gb RAM host running Tahoe 26.3.1, with Windows 11 Home Parallels VM Windows Feature Experience Pack 1000.26100.291.0 OS build 26200.7840 version 25H2.
Spreadsheet study for Trading added to MNQH6.CME all running fine.
Select spreadsheet tab, select cell A3 then Spreadsheet > Cell Properties > Text Color (List) > select custom > Text Color > select red > select OK.
Reliably crashes the terminal and the programme exits.
[2026-03-12 18:49:55]
ForgivingComputers.com - Posts: 1256
It is not specific to @diatom's setup.
I can confirm the problem exists on 2888 with both x86 and ARM versions, Mac and PC.
In all cases, crash or not, the colors do not change because the correct procedure is to click Automatic and change it to custom first. However, when changing both to custom and selecting new colors, the colors do change and then it crashes. (Version 2888)
Date Time Of Last Edit: 2026-03-12 22:17:03
[2026-03-13 13:35:22]
Sierra_Chart Engineering - Posts: 25489
We are checking on this.
