Date/Time: Tue, 10 Nov 2026 17:33:09 +0000
Extension of my Trail time.
View Count: 318
| [2026-03-11 14:58:25] |
| User322686 - Posts: 1 |
Dear Support, I passed a lot of time to learn Sierra Chart and did not have enough time to do some useful simulation trading. I will appreciate to give me another 21 days of trial before I start to do real trading and creating a real account for trading. Thanks for your understanding. Best Regards, Vigen PARSANIAN |
| [2026-03-11 15:58:27] |
| John - SC Support - Posts: 48483 |
Our records indicate that you did not use 6 days of your Trial Time, so we have added these to your account. We can not give another full trial. Once you have used the time from the trial, then you would need to change to a paid package to continue to use the software. We do have our "Base" packages, which are a little cheaper and meant to be used for continued learning or development. You can not get real-time data with these packages or connect to trading services, but you do have access to our Delayed Streaming data. Refer to the information on the packages at the following link: Description of Service Packages and Pricing: Packages When you are ready to change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
