Date/Time: Thu, 26 Nov 2026 03:31:23 +0000
Cant open C++ from Analysis->New/Open Study
View Count: 394
[2026-03-11 07:08:11]
User308424 - Posts: 78
Hi, I have SC installed on my D drive.
The path of default editor is set to D drive as well under Globalsettings->general settings-> text editor path and filename AND under Advanced Custom Study Editor Path
When I try to create new study via Analysis->New/Open Study->enter filename and press open C++ is not opening.
I see file being saved though in the list of studies above.
Will you be able to assist please?
Thanks!
[2026-03-11 14:36:21]
What editor are you setting up to use for this?
Sierra Chart no longer sends Notepad++ with our software, due to some issues with Notepad++ servers getting hacked about a month ago.
So you need to ensure that whatever editor you are setting up actually exists. If you want to use Notepad++ for your editor, then you should download and install it to your computer, and then set the editor path appropriately.
[2026-03-11 14:45:06]
Thanks very much! :)
