Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
Bluetooth controller not placing orders anymore
View Count: 320
| [2026-03-10 11:14:43] |
| User151964 - Posts: 3 |
Hello, last year I have made using an ESP32 a custom bluetooth keyboard with only 3 keys - B, S, F, mapped them as shortcuts in Sierra for buy, sell, flatten and it was working like a charm, this year after I have updated Sierra to 2888 64-bit, orders are not placing anymore, the controller is still working, I've even used it to remap the shortcuts, the letters b,s,f are showing in the "modify text" field of the chart drawings if I press them, should I tweak some settings? or did you removed some features? the controller is 100% working...
| [2026-03-10 14:42:32] |
We have not made any changes in this regard. We are not sure what you mean by "I've even used it to remap the shortcuts". Therefore, make sure you check the "Keyboard Shortcuts" and that items are setup the way you want them. The keyboard shortcuts should not have changed, but it is the only thing we can think of as to why there would be an issue with what you are doing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
