Date/Time: Thu, 26 Nov 2026 04:21:36 +0000
Keep Chart Drawing Selected After Creation Feature Not Working
View Count: 486
| [2026-03-10 10:22:12] |
| Daniel - Backtesting.club - Posts: 177 |
Hi, I want to report a bug in the "Keep Chart Drawing Selected After Creation" feature. If "After Single Tool Use Change To" is set to Hand, then after drawing any drawing, the object does not remain selected. For drawing modifications, everything is OK. Here is a video: https://youtu.be/m8wRjaxTo5c |
| [2026-03-12 14:36:13] |
| Sierra_Chart Engineering - Posts: 25489 |
This behavior really makes sense, but we will look at this and see what can be done.
| [2026-03-12 15:22:28] |
Thank you, I appreciate it. Clicking on the drawn object after it has been created is an unnecessary extra step that I would like to avoid. I hope it can be fixed. |
| [2026-04-08 16:22:15] |
I just wanted to ask if you've had a chance to look into this issue yet? Will it be fixed? Thank you.
| [2026-04-09 19:21:26] |
We apologize for the delay. We will be checking on this.
| [2026-04-09 19:36:24] |
No need to apologize. I understand you have a lot on your plate. 😉 Please let me know when you've reached a conclusion. |
| [2026-05-04 16:41:16] |
I don't mean to be a bother, but since it's been almost two months since I brought this issue to your attention, I'd like to know if you've looked into it yet. Thank you.
| [2026-05-05 00:03:43] |
A solution to this will be implemented in the next release but we hope it does not cause complaints/issues though for other users. When changing Chart Drawing tools, the existing selected drawing will remain selected if changing to the Pointer, Chart Values or Hand tools. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
