Date/Time: Thu, 26 Nov 2026 03:31:21 +0000
SC will re-download all the wave files generated by SC TTS
View Count: 323
[2026-03-09 14:49:20]
User543467 - Posts: 11
SC Support Team,
It seems to be linked to my username, I tried turning off almost every setting to stop the alert files from downloading,
but nothing worked.
After fresh-reinstalling and logging in with my username, SC downloaded the wave files I had used before that were generated by SC TTS. This happens every time I log in to SC, even before opening a chartbook. It immediately downloads all the wave files and saves them in the AlertSounds folder.
thanks,
Terry
[2026-03-09 16:44:39]
You can go to the following page for your account and delete the Text to Speech files you want:
https://www.sierrachart.com/UserControlPanel.php?page=TextToSpeech
If you want to keep them, but stop the downloading, then you can turn off downloading of files at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies#FileDownload
Although we do not recommend turning off all downloads, as this will prevent ALL files, including any third party studies, or files shared with you from downloading. It is best to remove the files you do not want.
