Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
Visual Ghosting/Redundancy on Last Bar when using Candlestick Overlaid in my Dom
View Count: 319
[2026-03-09 10:32:41]
User105485 - Posts: 2
hello Sierra Team,
I am experiencing a visual rendering issue where the last bar appears "doubled" or redundant. I have overlaid a standard Candlestick chart on my Dom within the same chart region.
Is there a specific setting I should use ?
best regards.
Ayoub
Private File
[2026-03-09 16:14:10]
This would be due to the source chart having a higher timeframe than the Trading DOM. Set the "Bar Period" for the Trading DOM to match the source chart to resolve this.
But, if you are wanting to view bars with the DOM, then it is best to use a standard Chart rather than using a Trading DOM with an overlay.
