Date/Time: Fri, 06 Nov 2026 12:49:52 +0000
Large Volume Trade Indicator
View Count: 429
| [2026-03-09 06:55:49] |
| User502486 - Posts: 2 |
Could you please modify the Large Volume Trade Indicator so that the sphere can be displayed semi-transparently and can also show numbers? If I set it to display numbers, the sphere should not be semi-transparent. Many other trading software platforms already support this feature. Could you please help submit a request to improve this indicator? I really like Sierra Chart. I’m not sure if I just don’t know how to set it up, or if this indicator doesn’t support this configuration yet. If it’s not currently supported, could you please submit a request to have it updated? Thank you very much. |
| [2026-03-09 16:10:05] |
| John - SC Support - Posts: 48449 |
There is not a way to do what you are asking for. We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-19 14:31:12] |
| Sierra_Chart Engineering - Posts: 25390 |
We are looking into this.
| [2026-06-17 22:19:34] |
Regarding the first post, update to the latest release. This will work as intended. Let us know if you have any further issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
