Date/Time: Thu, 26 Nov 2026 03:31:23 +0000
Regarding big trades indicator ERROR
View Count: 379
| [2026-03-09 02:11:25] |
| ArmaanSingh - Posts: 23 |
hi, I use you large trade indicator on ES 15min chart and volume value is set to 120, And one on 10 tick range bar chart and value is set to 25. However some trades are shown on range bar chart(Smaller timeframe), but not on M15 chart As if you going to look at around 21:20 on range bar chart, there were 237 contracts executed, while if look on M15 chart, it does not showing that trade although it set to 120 volume threshold |
| [2026-03-09 16:06:23] |
The value of 237 does not mean that there was a single trade of that size. It is the sum of all trades that were greater than or equal to the "Volume Threshold" you set. Refer to the following: Large Volume Trade Indicator For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
