Date/Time: Thu, 26 Nov 2026 03:31:27 +0000
Market Depth Historical Graph: visible bars..and visible range price
View Count: 623
| [2026-03-09 00:03:41] |
| Eranox - Posts: 41 |
Hello, The Market Depth Historical Graph currently scales the heatmap colors based on the min/max values within the visible horizontal time range (visible bars). What I would like instead is for the color scaling to also consider the visible vertical price range, meaning only the price levels that are currently visible on the screen. In other words, the normalization should be based on the maximum depth value within the currently visible chart area (both time and price). This is the same behavior used by the Bookmap heatmap, where the color intensity adapts dynamically to the liquidity visible on the screen. Is there a way to achieve this with the current study or would it require a custom study? If not, would it be possible to add this functionality in a future update? |
| [2026-03-09 16:02:12] |
We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
