Date/Time: Thu, 26 Nov 2026 03:31:25 +0000
Candlestick Chart With TPO-Style Functionality
View Count: 491
[2026-03-08 01:01:23]
User790187 - Posts: 13
I would like to create a chart that behaves similarly to the TPO Profile Chart in terms of profile management (for example the ability to merge profiles or split a profile into its individual 30-minute periods).
However, instead of displaying a TPO profile, I want the data to display as standard candlesticks.
Specifically, the default view would show one candlestick representing the entire session (RTH). If the session/profile is separated, it would split into its individual 30-minute candles, similar to separating TPO periods.
Additionally, I would like the ability to display the most recent ETH session as its own candlestick, similar to how the TPO Profile Chart can show the most recent ETH session profile.
Is there a way to accomplish this using existing chart settings?
My end goal is to have a chart where i can see the RTH candlestick and the RTH volume profile of individual session and merge / split them like a tpo chart allows.
Below I have attached a screenshot of what I have been able to build so far.
https://www.sierrachart.com/image.php?Image=1772931577792.png
Date Time Of Last Edit: 2026-03-08 01:03:02
imageMarch-07-2026-195807-Screenshot.jpg / V - Attached On 2026-03-08 01:01:06 UTC - Size: 212.46 KB - 212 views
[2026-03-09 15:07:58]
There is no support for something like this. The only option would be to have separate charts for what you want (i.e. Daily and 30m)
[2026-03-09 15:11:39]
Thanks for the response.
It looks like this feature has been requested by several users already. Are there any plans to implement it? If not, I’d like to add my request as well. Cheers.
