Date/Time: Thu, 26 Nov 2026 03:31:29 +0000
Positions Window Points
View Count: 459
| [2026-03-07 22:00:46] |
| Cileron - Posts: 52 |
Is there a way to change the dollar P&L to points inside the positions window? Right now, when I pull it up, it tells me my daily P&L in dollars, but I want it in points if possible. |
| [2026-03-09 15:06:20] |
That window is always displayed in Currency. There is not a way to change it to Points.
| [2026-03-09 15:29:22] |
Is there a way to see my net daily points for the day in Sierra Chart? Thats not multiplied by the amount of contracts I'm trading. Regardless of the number of contracts, it will show the points Example: If I traded 2 contracts and caught 12 points, it will show me 12 points instead of 24 points. Date Time Of Last Edit: 2026-03-09 16:54:24
| [2026-03-09 16:57:48] |
Use the Trade Activity Log and use whatever tab works best for what you want to see. Be sure to set the "Profit/Loss" for the Trade Activity Log to "Points Ignore Quantity". Refer to the following: Trade Activity Log: Profit/Loss Display Format Just keep in mind that if you setup the Trade Activity Log to view multiple symbols, then it will default to displaying in Currency - there is no way to change this. So you would only be able to view 1 symbol at a time to get what you want from the Trade Activity Log. You can also view the Daily P/L in whatever format, on the "Trading Window" for each chart. In this case, the Profit/Loss format is controlled through the following setting: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
