Date/Time: Thu, 26 Nov 2026 03:31:25 +0000
Feature Request: Copy All Charts Image to Clipboard
View Count: 502
[2026-03-07 07:18:46]
Piotr Grzegorzek - Posts: 36
ear Sierra Chart Support,
I would like to submit a small feature request regarding screenshot functionality in Sierra Chart.
Currently there is a very useful command called “Copy Chart Image”, which copies the image of the active chart to the clipboard. However, this function only captures a single chart from the Sierra Chart window.
In many trading workflows, users work with multiple charts arranged within the same Sierra Chart window (for example several timeframes or instruments). For journaling or sharing analysis it would be very helpful to capture the entire layout at once.
Would it be possible to add a command such as “Copy All Charts Image” (or similar), which would copy an image of all charts visible in the current Sierra Chart window to the clipboard?
This would allow users to quickly paste a complete multi-chart layout into documents, trading journals, or messaging applications without needing to take multiple screenshots.
Thank you for considering this suggestion.
Best regards
Piotr Grzegorzek
[2026-03-07 10:25:05]
Sierra_Chart Engineering - Posts: 25489
This has already been added. Update to the latest release. The command is on the Edit menu.
[2026-03-09 08:50:30]
There is a function to "Copy Main Window Image to Clipboard" which copies the whole window of Sierra Chart.
What is needed is a function to copy all Charts without the Control Bar and Title Bar of the Main window.
Best regards
Piotr
