Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
Window settings issue
View Count: 438
| [2026-03-07 03:27:09] |
| User443929 - Posts: 1 |
我想在DOM的图表里, 加入一些副图的二级指标 ,但是副图的窗口并不能自定义的去拉动调整窗口上下的宽度,在DOM的窗口设置里 互动式尺度也是没有锁定的,请问该如果设置才能让副图的窗口可以自定义的去调整它的大小或上下宽度呢?
| [2026-03-09 14:35:08] |
From Google Translate: I want to add some secondary indicators to the DOM charts, but the sub-chart window cannot be customized by dragging and adjusting its width. The interactive scale is also not locked in the DOM window settings. How can I configure it so that the sub-chart window can be customized to adjust its size or width?
If you are referring to the "height" of a region in the Trading DOM, then you are correct - this can not be changed. If you are wanting to view information like this, then we recommend using a standard Chart and not a Trading DOM. And we are not understanding what you are wanting to do in terms of scaling. The different scaling options will work in region 2. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
