Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
[Programming Help] - ACSIL - fatal error
View Count: 689
[2026-03-06 23:09:59]
User854341 - Posts: 1
I hope you are doing well today,
I was trying to build some custome orderflow using IA but when i would like to build it / import it into sierra there is a following error:
-- Starting remote build of Custom Studies Source files: zn_orderflow.cpp. 64-bit -- 23:04:55
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
The remote build is complete.
The build failed.
zn_orderflow.cpp:11:10: fatal error: SierraChartStudyInterfaceDefinitions.h: No such file or directory
11 | #include "SierraChartStudyInterfaceDefinitions.h"
compilation terminated.
Failed to generate the dll file.
-- End of Build -- 23:04:57
I was looking for this file - SierraChartStudyInterfaceDefinitions.h: but i dont have it in any sierra folder, my Sierra Chart version is 2888, service pac 11
[2026-03-07 09:25:30]
User431178 - Posts: 910
It does not exist...
Your AI hallucinated it.
#include "sierrachart.h"
Check here: Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function
