Date/Time: Thu, 26 Nov 2026 03:31:27 +0000
Display Overnight H/L on DOM
View Count: 391
[2026-03-06 15:56:38]
User165981 - Posts: 66
I have the H/L for time period extended on a chart. I tried to overloay that to my DOM but it didn't show. I changed the subgraphs to other studies I know work. How do I correct this?
[2026-03-06 16:20:26]
The most likely cause is that the High/Low are outside of the range of the values displayed in the Trading DOM.
Another possibility is that you do not have the lines extending to the current time. In which case, they will not show in the Trading DOM. Although the Trading DOM does not have the same display for bars as a regular chart, it is still drawing into it in the same concept, so any subgraph that does not have information at the latest bars will not be showing in the Trading DOM.
[2026-03-06 16:45:41]
I can use today as an example. Overnight low was 6737. I have the daily OHLC overlayed and it works fine so I copied the settingfrom that to the other study and that doesnt show anything. Is there soemthing else that I can use to plot the overnight H/L on the DOM?
[2026-03-06 16:48:59]
SOLVED: I needed to change the LINE STOP TIME to 16:00:00
