Date/Time: Thu, 26 Nov 2026 03:31:26 +0000
Copy Chart Drawing from another chartbook
View Count: 508
| [2026-03-06 14:57:40] |
| Cileron - Posts: 52 |
I know you can copy chart drawings from charts within the same chartbook, but is it possible to copy drawings from another chartbook
| [2026-03-06 15:36:35] |
You can copy drawings between chartbooks. Refer to the 4th paragraph in this section: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-06 15:41:57] |
| ForgivingComputers.com - Posts: 1256 |
You can copy most drawing types between charts, chartbooks, and instances with this. https://forgivingcomputers.com/product/fc-drawing-export-and-import-tools/ |
