Date/Time: Thu, 26 Nov 2026 03:31:20 +0000
[Programming Help] - How Can I Access TWS Columns for a SC Study - Specifically Shortable & Shortable Shares
View Count: 514
| [2026-03-04 15:58:36] |
| GeeMan - Posts: 11 |
Hi Everyone, I am presently trading US Equities in SC with IB. I want to pull some data from TWS to overlay on my Chart as a stufy. The columns i want to pull are 'Shortable', 'Shortable Shares', 'Fee Rate' & 'Utilization'. [Screenshot Attached]. Since the TWS API is already connected, is there an existing study where i can just tell it what columns to pull for example? Not entirely sure where to start - any tip/clue appreciated. Thanks in advance. https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=134716 |
| [2026-03-05 13:30:15] |
| mayerde - Posts: 4 |
Hi, great idea! As far as I understand though, this isn't possible natively, SC doesn't expose IB's Generic Tick types through ACSIL. Some alternatives worth trying: Fee Rate can be pulled from IB's FTP endpoint (ftp3.interactivebrokers.com, user: shortstock) via sc.MakeHTTPRequest(), though it only updates once a day. For Shortable/ShortableShares in real time, you'd need a separate process connecting directly to IB Gateway and passing the data into SC via a shared file. Utilization doesn't seem to be available through the IB API at all, only visible inside TWS itself.
Date Time Of Last Edit: 2026-03-05 13:31:53
| [2026-03-05 13:51:54] |
| Sierra_Chart Engineering - Posts: 25489 |
These fields of information are not supported in Sierra Chart.
