Date/Time: Thu, 26 Nov 2026 03:19:32 +0000
Trade Window for Chart
View Count: 519
[2026-03-04 02:59:47]
User950109 - Posts: 8
I am unable to see a trade window (floating) for ES. I can see one for MES. I used thee instructions and it never pops up up. I can attach the trade window to my Dom but I can't get it to float.
If what you want is a floating Trade Window instead of attached:
With the DOM active and the attached Trade Window visible, click the small M (menu) button on the Trade Window.
Turn off/unclick “Attach Trade Window to Chart Window” in that menu.
Now the Trade Window should undock and float; from here, Open Trade Window for Chart will just bring this floating window to the front whenever it gets buried.
If, even after detaching, Open still doesn’t bring anything up (no floating window at all), the next thing to try is a one‑time layout reset (Window → Reset Windows), then detach again; that usually fixes Trade Window position issues where it is technically open but off‑screen.
[2026-03-04 04:35:13]
Sierra_Chart Engineering - Posts: 25489
It is offscreen but there is a different command for the trade window. Refer to:
Basic Trading and the Trade Window: Trade Window is Missing or Does Not Appear
[2026-03-04 14:14:05]
Thanks!
