Date/Time: Thu, 26 Nov 2026 03:19:26 +0000
TPO Profile outline options
View Count: 515
| [2026-03-03 16:42:31] |
| BenjaminR - Posts: 185 |
Hello SC Engineering: I would like to change the color & style, or even turn off in some charts- the TPO Profile dotted outline and/or change the style. I've searched the forum & the manual, & the study settings as well as chart & global graphics- but cannot find anything. Please advise. Thank you, & make a great day! |
| [2026-03-03 21:17:19] |
The dotted outline that shows on a selected TPO profile (selected by left clicking on the particular profile) can not be changed. The reason it is showing is that you have setup at least one keyboard shortcut that relates to the TPO profiles. As such, there needs to be some way to distinguish which profile is being referenced, and that is done with this outline. If you want to not have it showing, then you would need to remove the keyboard shortcuts for the TPO actions. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
