Date/Time: Thu, 26 Nov 2026 03:19:31 +0000
Symbol position limits don't work
View Count: 340
| [2026-03-03 11:19:22] |
| mdomans - Posts: 5 |
Position limit setting is ignored. This worked as configured in previous versions of Sierra Charts 0. Latest version of Sierra Chart 1. I set position limit to 5 in global position limit (screen shoot) 2. Apply settings to chart 3. Test adding +1 contract (added 80 which seems significantly higher than 5) (screenshot attached) This has been broken for a while now, don't remember which version had it working but it did used to work. This is rather critical config element to many. |
Attachment Deleted. |
| [2026-03-03 15:39:49] |
We just tested this to ensure it is working in the latest release and it is working correctly for us. On your Symbol Settings window (Global Settings >> Symbol Settings) ensure that the option in the top left for "Use Custom Symbol Settings Values" is enabled (has a checkmark). Our guess is that this has been disabled, in which case any customizations to the symbol settings will not be utilized by the system. Refer to the following: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
