Date/Time: Tue, 03 Nov 2026 17:43:55 +0000
DOM Recent Bid Ask dissapears
View Count: 396
| [2026-03-03 07:30:42] |
| User453636 - Posts: 28 |
Dear Support Team! I have just updated my client to 2887 this morning. I'm using Rithmic as a data provider. When I set my DOM's tick size to 0.5, everything dissapears from the recent bid ask, and even tho price moves to a direction, nothing is appearing on said columns. If I set the tick size to 0.25 it appears again and working great! This happenes with Rithmic and SC Data (10 min delayed Denali) aswell. So I'm assuming it's a cliend sided error. Thanks. Tamas |
| [2026-03-03 07:56:58] |
| Sierra_Chart Engineering - Posts: 25362 |
There are implementation changes with this functionality and there is a standard way of doing combining and it is explained here: Global Trade Settings Windows: Combining Price Levels for Market Data Columns in the Chart/Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
