Date/Time: Thu, 26 Nov 2026 03:19:30 +0000
Replay mode Freezes
View Count: 365
[2026-03-03 05:58:21]
jethrogou - Posts: 56
Good day,
I have experienced some "play" "pause" issue in regards to replay mode when I decided to change "Charts with Same Link Number" to "All charts in Chartbook". Some charts work fine but the other charts are frozen while in "play". I have tried to use replay with a different chartbook and it seems like the issue still there. There are 2 charts that keeps reverting from "play" to "pause" and stays "pause". I have already changed the "Charts to replay" setting back to "Charts with Same Link Number" but issue still persists. How can I fix this issue?
Edit:
I've seen other support boards with the same issue and it might have to do with spreadsheet study since both of the affected charts have the same spreadsheet study. It doesn't make sense that changing the "Charts to replay" setting would affect the spreadsheet study that was previously working to suddenly stop.
Fix:
After looking at previous support board the fix that worked for me is setting "Use Column I and J Values Version 2" to "Yes" on your affected spreadsheet study
Date Time Of Last Edit: 2026-03-03 06:32:53
