Date/Time: Thu, 26 Nov 2026 03:19:32 +0000
After most recent update: Large Order Indicator Bubbles Moving randomly
View Count: 815
| [2026-03-02 18:50:54] |
| masedi - Posts: 63 |
Updated Sierra to latest version: 2882 / 55723 The large volume trade indicator is not working correctly after the upgrade. When the chart moves or scale range is changed, the bubbles move randomly around, even to untraded prices. Downgraded to previous version and issue is resolved. Please check that issue and let us know when it is fixed. |
| [2026-03-02 19:21:14] |
| User431178 - Posts: 910 |
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2887 Added new "Automatic Combining of Price Levels for Markers" Input to this study. When this is set to Yes, this enables dynamic combining of the volume for price levels based on the current scaling of the chart.
You can switch off the option that is causing that to happen. |
| [2026-03-02 21:40:39] |
With the option for "Automatic Combining of Price Levels for Markers" set to "Yes", we are not seeing markers placed in locations where no trades have occurred. If you can reproduce this, then please get us an image of what you are seeing. And please point out exactly where the issue is located in that image. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-02 22:26:28] |
Please see attached before and after some range scaling on the price.
| [2026-03-02 22:57:42] |
Please get us that chart with the Large Volume Trade Indicator on it, by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-02 23:55:02] |
attached
| [2026-03-03 02:10:52] |
| Sierra_Chart Engineering - Posts: 25489 |
There will be some improvement to this in the next release. However, what you need to do is set this Input to No: "Automatic Combining of Price Levels for Markers" This will resolve the problem completely. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-03 02:14:08
| [2026-03-03 17:44:19] |
I upgraded again to latest release and chenged the setting to NO and it works like before. Suggestion from my side: when a new parameter is added that changes behavior, make the default parameter setting OFF to maintain backward compatibility. Thanks |
| [2026-03-03 20:49:24] |
Yes we understand. The problem is actually fully resolved in version 2888.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-03 20:50:06
