Date/Time: Thu, 26 Nov 2026 03:19:31 +0000
Connection points not completed or OK
View Count: 277
| [2026-03-02 17:27:42] |
| User30743 - Posts: 399 |
What are these errors poping up every 10 seconds https://prnt.sc/dXvIYVd_HHdq It was not happening befoe and i did not change anything |
| [2026-03-02 18:16:34] |
You are having a problem connecting to your Rithmic account. There is nothing else we can state, as we do not know why or what may be occurring. Our only recommendation would be to try a different server and see if you can connect to a different server. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
