Date/Time: Thu, 26 Nov 2026 03:19:33 +0000
Global Graphics
View Count: 449
| [2026-03-01 15:40:13] |
| LongShortz - Posts: 53 |
In global graphics settings, there is an option to 'Save Settings' or 'Load Settings'. If I want to 'Save Settings', how can I create a new preset/configuration/profile to save my settings to? I would like to save my own custom set that I'd be able to load later but there doesn't seem to be a way to create new that I can find. Only Save/Load what is already there. I'm sure this is possible, can you point me to the proper instructions?
| [2026-03-02 15:26:13] |
You have the select the "slot" you want to save to or load from in the pulldown to the left of those buttons. Then you are select the button to either "Save" or "Load" for that slot. The instructions for this are here: Graphics Settings: Saving and Loading Multiple Graphics Settings Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-02 22:41:02] |
Yeah I'm familiar with this but the list of slots appear to be populated with a bunch of canned settings 'profiles'. There doesn't seem to be a method by which to removed them, or save new settings with a new name. Am I missing something?
| [2026-03-03 04:41:27] |
| Sierra_Chart Engineering - Posts: 25489 |
Yes there are 20 of those Saved Graphics Settings . You select one to Save into or Load from. Those are just the standard names.
| [2026-03-03 12:35:36] |
So I attached a photo. I don't know what all these profiles are. Are these the built-in default names you are referring to? (I'm thinking not). At one point, when I first came to Sierra Chart, I subscribed to a 3rd party product that simplified the application menus. Maybe it they came from that. Not sure, but when I select one slot to save settings in, I have no way to change the name to something that makes sense to me going forward. Is there a Sierra Chart file that I need to manipulate or something?
| [2026-03-03 12:38:02] |
Ugh, figured it out. Thanks for the help.
